I just did an engine swap, the previous owner smoked the 2.4, head gasket went out and drove it to the death of the motor. i dropped a new one in. I did a tranny filter and gasket also, the torque converter is empty, so is the radiator. How much fluid do i need? There is only a red cap with no dip stick. How do i check the level on this tranny???
Thanks!
1997 Cavalier Z24
Cold Air Intake
Dynomax Super Turbo Exhaust
Drop Zone 2" Springs
Black Projectors
HID Head, Fog Lights
20% Tint
I can't remember what my manual said,I think like 5 quarts,but after you fill it,there is a nut on the bottom of the trans,undo that ,if it comes gushing out,wait until it's slowly coming out,then it should be at the right level.
i think the check nut is on the passanger side of the tranny toward the bottom.
1997 Cavalier Z24
Bomz Short Ram Intake
Vibrant Cat-Back
KYB GR2 Struts
Goldline 1.75" Springs
RK Sport Upper Insert
RK Sport Lower Dogbone
Custom Tune by Shane @
innovativetuning@rogers.com
15.647 @ 88.02 MPH
whitegoose wrote:i think the check nut is on the passanger side of the tranny toward the bottom.
I remember my mechanic doing mine because i didn't know where it was and he had me look under the car while it was in the air,it's on the drivers side
Yeah there's a check plug on the passenger side. It's not hard to get too. Run the car till it's hot. Shift into all gears. Put car back in park. Jack the car up and make sure it's level. Usually that means you have to jack up the rear too.
WITH THE CAR RUNNING, remove the check plug. If fluid comes out, wait till it slows to a slow drip. If nothing come out, add some fluid, wait for it to spill out and slow to a slow drip. Put the plug back in, THEN shut the car off. If you pull the plug with the car off, you'll lose about 2 qts of fluid and the tranny will be under filled. I have done this with the car on the ground but it's kind of a pain to get to the plug. Easiest thing to do is run it up on some rhino ramps and then jack the rear up.
oops yes on the pass side,lol
Thanks all!
1997 Cavalier Z24
Cold Air Intake
Black Projectors
20% Tint
