a few issue im having problems with: cars is at 50,000 miles
1: Car is having a hard time starting, seems like battery but could it be spark plugs?
2: whenever driving above 5-10 mph when i steer i have a sound that sounds like a metal plate or something shifting from side to side.
3. after driving a couple miles sometimes my power steering pump will start acting up and i can feel it in the steering wheel and making noise when i stop and pull in to park...
anyone help me with these issues, identifying and what not.
OK, here's my go.
1. Does it turn over real slow, will it turn over fast and not fire?
2. ummm CV axle? IDK it's not described real clearly
3. How sure are you it's the pump? does it have fluid?
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
ill check fluid
it cranks slow then will take off after a couple times
ill check cv axle... hopefully your right
sounds like it could b possably worn out pads (the scraper hitting the rotor) and warped rotors (the stering wheel issue)
cold start issue could be eather starter, battery, battery cables
yeah, if it cranks slow, it isnt your sparkplugs, but likely the battery. autozone and such stores test them free.
thanks guys... ill get this stuff checked .... appreciated.
