my birghts went out a while ago and i didn' t really care at the time but last night i had to dirve to the middle of nowhere and i couldnt see a damn thing and i was wondering if anyone knows what could be wrong with them. if so please let me know. Thanks
fuse?...bulbs?.. other then that no real guess...
its not the fuse. and isnt it the same bulb as the headlight or the drl
do you have a sunfire or a cav? fill out your profile and we can help you more.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
does the hi-beam indicator still light up on the dash when you switch to brights? If so, it's probably not the switch. have you checked the bulbs?
yea the hi beam indicator does light up and i havent checked the bulbs yet but when i do i will let you know
yes it has a dual beam head light. however one filiment can go bad and the other works... does ur running lights work? it is the same filiment as ur brights....
my running lights do work but when i let down my e brake they flash about 5 times and turn off and the service light comes on, but if i turn on my lights before the drl's stop flashing the service light doesnt come on. i just replaced the bulbs with the sylvania silverstar ultras and the brights still dont work and i checked the fuses and i couldn't find a fuse for the brights, just both head lights and a relay for the running lights. if you have any other ideas of what i could be please let me know. thanks
