Like the subject line reads.....
It will flash for a couple flashes then stops....stops everything..no ticking....no flash no nothing...
I replaced the turn signal switch...still...not working properly....
Thoughts...?
I honestly thought this was going to be a joke thread...
fuses?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
I wish it was a joke...It's driving me nuts.....
Fuse is good...
I was pm'd something about a flasher fuse under the dash....?
Idunno but l'm gonna have a look...
Funny thing is my hazzards work with out a problem....they flash until I turn them off...
So all fuses should be fine.....Not..?
sounds like a flasher problem, but i am thinking the flasher is part of the BCM......i would have to look it up.....
That sounds like a take to dealship thing to repair.....?
If that's the case winter storage will be this weekend..!
Flasher is a bright (almost neon) green relay under the dash, it's hiding above the accelerator pedal on a plastic clip. Easy enough to change.
Either that, or you've got a bulb on it's way out or making a poor connection.
...j
^ I agree. Sounds like the flasher relay going bad.
98 Z24
RIP Specks
ZSleeper wrote:^ I agree. Sounds like the flasher relay going bad.
Thanks Guys...
John , if its the relay does it have a fuse of its own or do I simply buy a relay from the dealer cut the old one out and replace it
with the new one...?
Sorry, forgot about this thread!
No need to cut it out... it has a socket, you just pull it out to replace it. If the fuse to it was blown, it wouldn't fix itself. It's probably a shot relay. I get 'em at the wreckers, lots of them!! I have a few here if you wanna PM me your address, I'll mail it to you..
...j
