vacuum problem!?!?! - Maintenance and Repair Forum
vacuum problem!?!?!
Thursday, September 25, 2008 1:01 PM
whats the most common place to have a vacuum problem...just changed engines my old one was fine this new motor has a leak somewhere i believe
Re: vacuum problem!?!?!
Friday, September 26, 2008 8:19 AM
car? engine?
Friday, September 26, 2008 2:43 PM
with the engine running, get a can of starting fluid and spray it in different areas around the engine. if you spray and the idle rises, you've found the general area of your leak.
Saturday, September 27, 2008 8:12 PM
ok thanks ... just gotta switch gas tanks and see if its my fuel pump that is making my car completely bogg out if its not that its my vacuum problem ... i know i have a vacuum prob
