ok today im guilty of trying to drift my FWD cavy....yea i know im dumb for it lol sorry. on the drive home the steering was fine. a few miles down the road later i pull into my friends gate and i hear a grown while turning(aaaawww @!#$) was my thoughts. when i parked it i saw fluid under the car coming from the left driver side. i looked in the power steering tank and it was drained. i put somemore in the had stop leak added to it and it stopped for a few minutes. after this i parked the car and took my friends. came back drove it to the gate and the groans come back. when i finally get to my house i see leaking from the driver side and the passenger side. i kept the car running and i looked in the power steering fluid tank and it look like it was gargling and the fluid was low and foamy. so i added more fluid plus a separate type of stop leak. i turned her off and put her to sleep for the night. tomorrow im taking her to the shop. anybody know what i broke or busted b4 i take it to the shop and an estimate of the cost.?????
just b y telling us that fluid is leaking doesnt indicate anything. more than likely its a busted line though
probably a high or low power steering hose... easy fix if you know where they are located. they are the two lines that go from the pump to the rack.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
come to find out it was just a loose line that needed to be tighten. jacked the car up and stuck my hand through a very small hole and tighten the lines. booya fixed. no more drifting.......................................................................for now
No more stop leak.. dont ever use stop leak.. for anything.
y not? whats wrong with it
it stops more than leaks.
Redhotchevy2000 wrote:it stops more than leaks.
LOL x2. Let's just call it a dirty bacteria-filled band-aid
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
