Hey. I've got 1 quick question. Is the valve cover gasket on the 2.2L 2200 (98+) a one-time use gasket, or one of those multiple use gaskets that can be used 2-3 times?
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
get a new one dont be cheap
im not being cheap smartass. why dont u get educated and not be ignorant and assume @!#$? some gaskets are designed to be used up to 3 times like the transmission pan gasket w/ no problems.
The valve cover doesnt see pressure, so if it still fits in the location where it sits, then you can re-use it. If you find it tries to pop out because its stretched, thats an indication it needs to be replaced.
Edited 1 time(s). Last edited Tuesday, July 29, 2008 8:06 AM
Toronto Cavalier wrote:im not being cheap smartass. why dont u get educated and not be ignorant and assume @!#$? some gaskets are designed to be used up to 3 times like the transmission pan gasket w/ no problems.
i sell parts for a living, and honestly, every time i remove something that has a gasket, i replace the gasket. i know, i know, you can re-use them, so the company says. i've NEVER had a gasket seal right the second time being used. just buy another one, it's like $10.
