So my fog lights haven't worked sense I bought the car. Deicided last week I would fix them. So here I am now after replacing
everything except the harness itself and there still not working. New bulbs, relay, switch and nothing. I'm wondering if maybe I have to
clean the harness alittle? The rocker switch the also doesn't light up either. Any help you guys and gals could give would be much
appreciated.
"Thank you little roots; Stay strong." Chris Farley
So I cleaned the connections with some electric cleaner and still nothing. This is really starting to bug me. Anyone have any clue?
check the wiring that leads to the relay.... I had the same problem and the wire that stays hot had burnt itself out..
Yea I suppose its the only other thing to do. Gonna have to hit my friend up for the multimeter I suppose. Thanks for the help!
When my fogs didn't work it was because the relay wire running to the switch had ate itself. Took me 3 hours to get that figured out :/
