3 cavy's all with same problem - Maintenance and Repair Forum
Wednesday, July 09, 2008 9:41 AM
I know of three cavaliers with the same problem. The years are 1996, 1999, and 2000. The 96 is my car. They all have a hard starting when cold problem. Its almost like it looses fuel prime on all of them. It cranks probably 3 seconds before it will finally fire up when cold. It occures as soon as 15 minutes after the car is shut off. Anyone have any ideas?
Re: 3 cavy's all with same problem
Wednesday, July 09, 2008 9:31 PM
Try just passing the switch to on for 2 swconds, then start...this will give the pump time to prime the fuel system and it should fire up right away.
Thursday, July 10, 2008 2:47 AM
You call 3 seconds a starting problem? Just about every manufacture I have seen the info for says that it is normal/acceptable to take up to 10 seconds to start.
Thursday, July 10, 2008 6:45 AM
mitdr774 wrote:You call 3 seconds a starting problem?
I would. If my 1997 Cavy turns over more than three times before catching on a cold start, it's out of the ordinary.
    Shop Manuals, Brochures:www.kenmcgeeautobooks.com
Thursday, July 10, 2008 10:41 AM
Mine generally starts on the 2nd or 3rd crank.
Might be a plugged filter or bad fuel pump.
Thursday, July 10, 2008 7:22 PM
# seconds is well within the acceptable limits of starting time by most manufactures.
Wednesday, July 23, 2008 6:19 AM
it start in like 2-3 cranks when the car has just been run and you are restarting it within 5 mins otherwise sometimes it cranks for up to five seconds then stumbles a little bit then starts.
Saturday, July 26, 2008 7:33 PM
fuel pressure regulator. cheap easy fix might work. sure cured my hard starting.
This life goes passin you by
It might go fast if you like
You born, you lived, and you die, oh oh ohoh
If life goes passin you by
Don't cry
If you're breaking the rules, making your moves, paying your dues
Chasing the cool
-Lupe Fiasco
Saturday, July 26, 2008 7:57 PM
Pull the vacuum line off the regulator. If there is fuel there, replace the regulator. Could be a leaky injector also.
Wednesday, July 30, 2008 7:24 AM
Smell the oil for gas. I had a leaky injector. I waited about 1/2-1 hour after shutting it off & pulled all the spark plugs then shined a light down in the cylinders (I have a small light w/flex head that works great for this) & found the cylinder that was wet. Hope that helps.
