kind of a sputter - Maintenance and Repair Forum
kind of a sputter
Tuesday, July 01, 2008 1:14 PM
ok so a while ago my car started sputtiring then one day omw home it lost all power i was in first gear and going 20 miles an hour and wouldnt pick up speed sounded like a mopad like 2 cylinders and was throwing the multiple random misfire code so i put new plugs wires and coil packs on and a new fuel filter everything has been going fine but today it started sputtering again from when i take off all the way up my rpm range it does it im lost now on what it could be anything would be helpfull and when it does it it still picks up speed but it bucks a little and the cel isnt coming on
"how do you get in"
Re: kind of a sputter
Wednesday, July 02, 2008 11:56 AM
Is the cooling fan running? If so, you could have a pending code that hasn't thrown the light yet.
My sputtering which sounded just like you describe ended up being a dying fuel pump. Not saying that's what your problem is... but it could be.
My cooling fan would come on for (what I thought was) no reason at all.. then I checked the codes, and there was a pending P0171 lean code... checked the fuel pressure, and it would come and go... sometimes it was fine, other times the pump would just stop for a second or two.
Thursday, July 03, 2008 6:52 AM
i think i figured it out one of the plugs on my coil pack and one of the prongs inside the plug was all messed up my step dad bent it back rite and it was fine cause i pulled spark plug wires 2 and 3 and there was no spark so i looked at the plug to the coil and it was all messed up my step dad said it prolly did it when it heated up and the prong got loose
"how do you get in"
Thursday, July 03, 2008 8:32 AM
Yea, if the oil packs are not seated on the ICM right, you will get the problem your having.
Thursday, July 03, 2008 12:20 PM
wat do you mean not seated rite to the metal bracket that holds them cause one of my bolts are stripped out but its the opposite coil of the one that wasnt fireing
"how do you get in"
