tcc question - Maintenance and Repair Forum
tcc question
Wednesday, June 11, 2008 12:46 PM
ok on a 94 cavalier 2.2 the tcc solenid went bad because so i want to know how would i change it?
Re: tcc question
Thursday, June 12, 2008 10:02 PM
Well not being exact on the specifics here is my two cents.I know that the part in ? should have two plug harness (not 100% sure but should be) and I know auto zone and advance auto parts do show pics of the part in the topic. It is a screw in part threaded and it's pretty simple to remove and reinstall and plug the electrical plug in.Both auto stores label this in there trans parts as a solenoid to the best of my knowledge and there is a post in 2nd gens about this.I would HIGHLY recommend u change the trans fluid and filter bc the fluid is TOAST which is what burned up the switch to begin with bc of age and fluid breakdown due to wear and heat.I would not buy the part and repl with out doing the fluid/filter change bc u will fry the new part with old fluid in a short amount of time.Check the 2nd gen forum if u have ?s on this it is there.This will help.
Re: tcc question
Friday, June 13, 2008 7:36 PM
Here you go, it is a pretty good write-up:
http://www.v6z24.com/howto/tcc
BTW, the pic in it was from when I did mine. A 91 RS wagon (RIP)
Re: tcc question
Monday, June 16, 2008 3:30 PM
hehe if you dont have money just unplug it for now
Re: tcc question
Monday, June 16, 2008 6:19 PM
it is unpluged now but i want to fix it where can i buy it because the one they show at autozone is not that connector at all.
Re: tcc question
Wednesday, June 18, 2008 9:28 PM
http://www.autozone.com/R,APP767099/vehicleId,1954802/initialAction,partProductDetail/store,2436/partType,00623/shopping/partProductDetail.htm This should be the part YOU need based on ur info 94 cav 2.2 granted the plug may not look like urs but u can always modify it to plug up with some new plugs of course.Keep in mind it looks to literally plug in not screw in like I stated initially.I know alot but not all the specifics.
