metal shavings in oil filter - Maintenance and Repair Forum
Saturday, June 07, 2008 9:18 PM
hey whats up guys. this is the first filter ive seen that you can actually see the paper filter. and its been about 2 times already that ive seen metal shavings.... do all yours do this? this is my first chevy. dont know if its kinda normal. change the oil everytime with mobil 1 and its got about 75,000. hope im not the only one thanks.
ECOtec DOHC
Re: metal shavings in oil filter
Saturday, June 07, 2008 9:35 PM
how often do you change it? are they actually shavings or is it more just a little bit of shinyness?
Saturday, June 07, 2008 11:31 PM
My question is u have the metal shaving be fore or after the oil change or with the oil filter before it installed?.
Sunday, June 08, 2008 5:08 AM
the metal shavings are on the old filter when it is being replaced. .when dumping the old oil into a container. i can see very small shavings. i change my oil every 3000 miles.
ECOtec DOHC
Sunday, June 08, 2008 7:12 AM
normal
Sunday, June 08, 2008 11:34 AM
If its lil flakes of metal, Yes its nornmal wear and tear. I get that in my 01 cavalier 2.2L, I see it very small amounts on oil changes.
Sunday, June 08, 2008 11:38 AM
thanks alot guys.
ECOtec DOHC
Monday, June 09, 2008 10:29 AM
if you have time and you wanna be extra careful you can just pull off your oil pan and check for any wiggle room in your rods.
wiggle room is bad...
z24 - CAI - Magnaflow Cat - PaceSetters
--exhaust and unorthadox pulley soon
Monday, June 09, 2008 11:38 AM
actually i changed the pan about a year ago. the old pan was cracked by a rock on the road. shoulda did that then. oh well. thanks for in the info.
ECOtec DOHC
Tuesday, June 10, 2008 8:15 PM
Wow this is a first to here small shavings are ok...I had shavings in my old ECO and I did a motor swap,But in my condition one of my timing chain guides let go but this is all new news to me...
Wednesday, June 11, 2008 12:32 PM
Rob S wrote:normal
No it's not. Thats a *ucking bad thing, I've done numerous oil changes on Ecotec engines (with the cartridge type filter) and I have never seen metal shavings in ANY of them.
Wednesday, June 11, 2008 5:54 PM
Agreed^^ ... last time i checked oil shavings in the oil isn't a normal accurance.
A truck just came in at work with a bad engine knock, tech pulled the oil, had a small amount of oil shavings in it, you could see them sparkling and he used his magnet to pull a bunch out so i could see and needless to say that truck needs a new motor. So i'd check it out with your local mechanic or something before forgetting about it.
(99 - Sunfire - Red - 2200)(95 - Cavalier z24 - Purple - 2.3 quad four)
Wednesday, June 11, 2008 6:11 PM
OK good to know I thought that was kinda funny...
Friday, June 13, 2008 4:31 AM
i was finding lil metal "bits" in my oil on my 2.4L twincam....
at first it was just tiny lil metal specs... almost like dust....
then the next change it was small particles...
then the next there were actual flakes...
and then i spun my rod bearing and needed a new engine before i got the the next oil change.
now that i look at my torn up bearings... i see where the shavings came from...
If i were you... i would spend a weekend and get yourself a new set of rod and main bearings, and pop them in the car now while she stil is in the early stages.
it might cost ya $150 in parts and a weekend in the garage..... but if ya let it get any worse, you will be like me and find yourself a few grand poorer cuz you didnt.
Monday, June 23, 2008 7:03 PM
thanks guys again.
ECOtec DOHC
