So this past weekend I changed all the timing components and reassembled everything BUT, I did not turn the crank 720 degrees afterwards to see if everything was ok. I do remember that everything seemed ok when i put it back together. The crank notch was pointing up and the pins went in and out easily on the camshaft sprockets. So do you guys/girls think I'll be ok? I've already put the engine back in the bay was just now thinking about this. Thanks.
If it was done right you will be ok. If it was me I would pull the cover off and check. You can do this with the engine in the car.
^^^never hurts to check. you dont want it to be out of time or something when you try to start it.
didn't feel like pulling the cover since i had worked on the car so much already. I was just frustrated and tired so i started the car and all is good. it runs great now.
