ok so i have a 95 thru 99 cav , i did a 00 front end swap got the harness and wired them up the correct way and every thing
the lights worked all day yesterday, but now today the drive side light is dim and wont flash from high to low beam
it just stay really dim,
checked fuse's
checked bulbs
tried to use a diff harness and checked for any cut or grounded out wires
but i still cant seem to figure it out
some one please help
thanks
chris
check you grounds. since our headlights used switched grouds
i checked my ground on my battery and stuff
what else can i check
Sounds like a DRL problem.
i cut the blue wire under the dash, to disable them
it was doign it before and after i cut the wire
are you using the correct relays ?
i was never told to use any relays, just cut the hold lights off then wire the new harneses on and thats it
they worked fine all day yesterday, just went to mess wit the car today and the one just stays dim now
yea your gonna need those replay i believe there the same replays for the DRLs ..
check this out
http://www.j-body.org/forums/read.php?f=7&i=348551&t=348551
its works .. as long as you disable the DRls but i see you did already, only down side of this is the high beems only works for the passenger side.
yea the light works on the pas side
the dam drive side wont do @!#$ just dim as @!#$
broken wire behind drivers side of bumper
