re-using head bolts (2 months old) - Maintenance and Repair Forum
Saturday, May 03, 2008 6:09 PM
I just replaced my head like 2 months ago, put brand new head bolts in it... Now i spun a bearing. gotta pull the engine apart and have it re-done... i know you are not supposed to re-use head bolts... but considering mine are brand new and maybe only had 1000 miles on them.... can i still use them? or just scrap them and get new?
And how about gaskets... same deal... they are all brand new... which can I re-use, and which will i have to scrap and buy again?
rather not have to buy another $200 gasket set.... but rather not have a big leak and have to tear the engine out again either.
Re: re-using head bolts (2 months old)
Saturday, May 03, 2008 6:16 PM
No. They are torque to yeild bolt. Which means they are a one time use bolt and cannot be reused.
As for the gaskets, i would get new. Better being safe than sorry.
Saturday, May 03, 2008 6:17 PM
Tinkles wrote:No. They are torque to yeild bolt. Which means they are a one time use bolt and cannot be reused.
x2. no reason to cheap out if you're pulling the engine.
Saturday, May 03, 2008 6:24 PM
ok... well what about ARP head studs? are those re-usable? or is that a one use thing as well?
i know alot of the gaskets in the kit are rubber re-usable ones.... and probably 40% of my kit was unused anyway...
so i really hate to spend another $200 on a full set... can you buy individual gaskets? and can i get away with re-using my re-usable ones... (cam cover to cam tower, timing cover, etc)
I assume my head gasket is trash now eh? (i was thinking about going with a cometic or something anyway, now that i am having the block machined)
Saturday, May 03, 2008 6:31 PM
buying individual gaskets is a possibility, depending on how many you need however, it can get costly. yes, the rubber/silicone gaskets can be reused. however, head gaskets, any foil, metal, or paper gaskets, MUST be replaced. i would ask arp if their studs could be reused, as i myself am not sure.
Saturday, May 03, 2008 6:56 PM
Yeah you can buy individual gaskets. Go through NAPA. I bought all the gaskets/bearings I could possibly need separate for far cheaper than it would have been to buy the "set", it's hilarious.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Saturday, May 03, 2008 8:14 PM
ARP head and main studs are reusable. Most of teh gaskets can be reused. the HG is junk now. I would avoid Cometic if at all possible. The stock graphite one is more than capable of handling a lot of abuse.
Sunday, May 04, 2008 4:08 AM
Yes ARP studs are re-useable, as long as you do not blow a head gasket. ARP told me that it you are rebuilding a motor because of bottem end failure to re -use them, but head gasket failure do not reuse.
