Gas Guzzler!!! HELP!!! - Maintenance and Repair Forum
Thursday, March 27, 2008 11:12 AM
i drive from missouri to chicago, every few weeks, n it usually takes close to half a tank. but now it take a full tank plus some. and it started doing this suddenly. has anyone had this happen, or know what the cause coulde be. i was told that it may be the oxygen sensor. but is there anyhing else it could b or does that sound right.
Re: Gas Guzzler!!! HELP!!!
Thursday, March 27, 2008 11:22 AM
What kind of car is it? My 2200 powered J-body started guzzling gas as well. It's a common thing it seems. Had the Oxygen and Air/Fuel sensor changed and the injectors cleaned and nothing. In fact, I had it checked and apparently the car's running fine. My mechanic thinks it may be the winter gas that's causing havoc with the sensors. I dunno.
Thursday, March 27, 2008 11:35 AM
Knoxfire wrote:What kind of car is it? My 2200 powered J-body started guzzling gas as well. It's a common thing it seems. Had the Oxygen and Air/Fuel sensor changed and the injectors cleaned and nothing. In fact, I had it checked and apparently the car's running fine. My mechanic thinks it may be the winter gas that's causing havoc with the sensors. I dunno.
your mechanic is an idiot....he just wont admit that he has no clue wht the problem is.
anyways....do you notice any lack of power? could be a bad cat
usually a bad o2 is gonna throw a code.
check your air filter lately?
Thursday, March 27, 2008 11:47 AM
i think a bad cat is a problem with a lot of j body owners and they just havent figured it out
Thursday, March 27, 2008 12:32 PM
Hmmmmm... that may be. Because the air filter's been changed as well. Bad cat you say? I'll have to check that out.
Thursday, March 27, 2008 3:12 PM
ill hav all that checked out.
