Window control switch problem? - Maintenance and Repair Forum
Friday, March 14, 2008 2:33 PM
Window goes down fine, but up i have to press really really hard.
Do I need a new switch or does it have a spring that can be adjusted? How do I remove this anyway?
Re: Window control switch problem?
Sunday, March 16, 2008 6:44 AM
I had the same issue and it was a small roach that somehow got into the switch and was interrupting the contact to rise the window, got it out and problem solved! I t is tricky to get the cover of the switch out it has some small eyelets on each side that you have to pry sideways to pull the cover out., It can be broken easily since it is plastic so just be patienceand donīt use to much force, and you have to get the whole switch assembly out and place it upside down to do it if I remember right. You could use some electronic cleaner spray also.
Good luck.
