is it possible to leave the 5 speed transmission in place and just pull the engine out? This is for a 99 Z24 if that makes any difference.
I have read conflicting information saying if you leave the transmission in you will ruin the splines on the shaft, but others say it is perfectly okay. So I am just looking for a second opinion.
Thanks
Jeremy
<img src="http://www.jhatch.com/locker/snappzz.jpg">
ya ive had my motor out twice, left the tranny in both times. all ya gotta do is lift 1 side of the motor up as far as it will go, then put a block under the trans and unbolt everything. Its a tight fit but it shouldnt be a problem.
did you have to remove the crank pulley? Also where do you normally put your jack stands? I am used to the 2nd gen frames.
i dont think i removed the pully, i cant remeber but it woundnt hurt. um, theres jackin pionts on the rocker, but i always but them on the frame lookin peace farther in up front and the swingarm pivot on the rear
cool, thanks for the info.
