HELP (timing) - Maintenance and Repair Forum
HELP (timing)
Thursday, January 10, 2008 7:05 AM
i am doing the timing chain on my 97 z24. i replaced the gears, guides, and tensioner...all the marks are lined up perfectly, and cylinder 1 is at tdc. But i did not mark my old cam gears...would accidentally swapping the intake and exhaust gears cause my car not to start?
Re: HELP (timing)
Thursday, January 10, 2008 7:16 AM
No, you'll be fine.. Just get the marks lilned up and your good to go.
Re: HELP (timing)
Thursday, January 10, 2008 12:10 PM
i have all the marks lined up...everything is perfect...cylinder 1 is at tdc, and all the marks are on the money. and that is the onlything i can think of.
Re: HELP (timing)
Friday, January 11, 2008 7:08 PM
there are casting numbers on the cams, look for those then log on to www.quad4forums.com and look for info there
Re: HELP (timing)
Saturday, January 12, 2008 2:53 PM
nevermind...it's up and running again. cylinders 3 and 4 weren't firing, but i have a small leak coming from the back of the engine bay...all the bolts on the w/p and the housing it bolts to are tight...has anyone had that problem before? (it is just a constant drip)
