anyone nkow how to deactivate the day time running lights? i tried opulling a few fuses and nothing works. either i have just head lights and no fogs, or nothing at all. is there a fuse for JUST the day times?
thanks...sounds like an easy task...but im not mechanically inclined with this stuff so im sure i will F something u! lol
pull the E-Brake up one click. One click shouldn't touch the rear brake drums.
for safety I wouldn't disable them because you never know who might pull infront of you or almost did or was going to
what year is it? i disabled mine by grounding one the wires on the bcm and i havent had a problem at all. No flashing drl light or anything. By grounding the one wire the computer thinks they r on but there not. if its a 2000+ it will work. ill double check on the color of the wire but i think that is is the dk. blue wire coming out of the bcm. but ill double check.
that sux because its a 98
Pull the relay in the fuse box and live with the drl light blinking
there is a way to disable them on the 95-99 i dont remember how off the off the top of my head but ill look and see if i can find it. It involves removing the gauge cluster and grounding the one wire. Ill look it up and let u know
OneQuikZ24 wrote:thanks...sounds like an easy task...but im not mechanically inclined with this stuff so im sure i will F something u! lol
If this statement is true then don't attempt what was said ^^^^above,if pulling the relay and running a jumper
wire is too difficult then just pull the relay.Of course you won't have both brights but that is why you run the jumper wire.
I would also check with your local laws..... if your state/province requires DRL's and you disable them and then are involved in an accident you could be in for some legal troubles....
no worries, jay van gets a police escort on burger runs, the police ask HIM what the laws are every day when he wakes up and decides to enlighten them
