ok so im having trouble with my wipers and blinkers. the problem is i have none. first it started with my wipers going out then a week later the blinkers went out. i checked all the fuses and switched relays around cause i dont know how to check relays. i just switched the relays with ones that i knew worked. all seemed fine.
i really need some help here.
thanks
As to the blinkers it could be the flasher... I would check the connections to the wiper motor and switching them on try moving them by hand see if they go.
Ok ill try that. but for the blinkers what do you mean by flasher?
did you use your wipers as s now brush? if so check your fuses.
check them anyway
Is the wiper switch on the turn signal control arm? If so you might have a bad power or ground wire or might need to replace the whole assembly.
The flasher is a small plastic box a sort of relay its function is to turn on an off intermitently the lights(turn signal and blikers) it is usually under the dash and maost of them make some noise like clik,clik as they work.
I would say-- Replace the switch assembly like Dan said.
if your wipers don't work then you need wiper fluid hehehe
Just joking
OMG! that was funny!!! Sorry- I'm bored
I guess I'm goinna get bored somewhere else
Peace!
ok, that was funny, I was taking a drink when I saw that and almost spit it out on my screen,
maybe its not that funny, but with the day I had, it was a good one.
