The - Maintenance and Repair Forum
The
Saturday, November 24, 2007 9:53 PM
Well, I just finished up a basic flippin' rebuild of the rear brakes....all in all it went well for a drum brake job.
Problem is...now I have no brake lights. The third brake light works as do the turn signals, hazards, and parking lamps, but no brake lights. Also, I checked the applicable fuses and bulbs...they're all good to go. I've heard that this may be caused by the brake on/off/ switch (or BOOS).
I figure that the BOOS got jammed up during the bleeding process, being as it was a one-man bleed (don't ask...patented routine).
Does anyone have any experience with this issue, or if anyone knows a part number I'd appreciate it. THANKS!!!
A heap of broken images, where the sun beats,
And the dead tree gives no shelter, the crickets no relief,
And the dry stone no sound of water. Only
There is a shadow under this red rock,
(Come in under the shadow of this red rock),
And I will show you something different from either
Your shadow in the morning striding behind you
Or your shadow at evening rising to meet you;
I will show you fear in a handful of dust.
Re: The
WTF? This did have a friggin' title.....
