Head Gasket, cylinders 2 and 3 - Maintenance and Repair Forum
Sunday, November 04, 2007 4:57 AM
Hi, John Lenko
My 1993 2.2 Cav, having just passed 253,500 kms developed a rough idle.
Compression test revealed 1-150,2-75, 3-70,4-175
I thought at first valves,springs or piston rings but
No white smoke, coolant in oil.
I wondered if it was possibly a damaged gasket between cylinders 2 and 3-impossible- but no your post says it CAN
happen
http://www.j-body.org/forums/read.php?f=11&i=116416&t=116398#116416
Really, just to says thanks for the info
Alont
Re: Head Gasket, cylinders 2 and 3
Sunday, November 04, 2007 8:33 AM
I would first pull the spark plugs see if you got any kinda coolant deposites on youre plugs, Could have a tiny hole in the hd gasket. Are you losing coolant?.
Good Luck.
Sunday, November 04, 2007 12:37 PM
Hi Rich
all spark plugs are a perfect colour-no deposits-no coolant loss
Alont
Sunday, November 04, 2007 2:41 PM
Could also have a part of the head gasket thats got a leak some where. Or intake leak.
Tuesday, November 20, 2007 7:11 PM
I realise this is "Old" by now but in case anyone has a similar problem.
Just an update, removed the cylinder head and took it to the local friendly machine shop.
Head was cracked and replaced,
Runs on all four again now
Alont
Tuesday, November 20, 2007 9:22 PM
yup same problem i have .. im in the process of doing a head change myself.. ill be done after thanksgiving haha
