So when i turn my wheel a quarter of the way to the left and to the right my steering wheel kinda pops i can not hear as much as i can feel it and sometimes i can feel it down on the pedals its weird i checked the power steering fluid and added a litle but i added a little to much so i pumped some out and it was dirty i dunno why. And also when i have my window down and i start off in first in second gear and kinda get after it it sounds kinda like a plastic wrapper is flapping in the wind
any help would be great
***Looking for a BLUE 03+ STOCK cavi wing pm me if ya got one you wanna sell***
That popping could be the intermediate steering shaft in need of lube, there is a kit available from the dealer that takes care of that, or a bad strut mount, or even your tie rod ends. Grease the tie rod ends, see if that helps any.
ok thanks man i will try that
try looking at the lower A-frame bolts i had the same prob on my 2000z24 but in order to check if its loose you have to remove the pitman arm,try to tighten it if it dont tighten then u need a new one,but make sure you put a second jack on the A-frame.
1.remove tire
2.place 2nd jack lightly under a frame
3.5/8 socket remove the pitman arm bolts
4.try to tighten the bolt in between the steel faceing the bumpers
5.replace it if nessery
