I've been looking for the place where the brake lights and turn signal sensor goes. I've been to the Local Chevy dealers and they say that it is up under the steering wheel dash, but I can't find it... If anyone has an idea, that would be great! thx
Nate
njsteven@iupui.edu
http://www.cardomain.com/id/NaptownCavyBoy
i think u mean switch, rather than sensor, and its not a combo switch, just 2 switches effect the same lights.
the switch for the brake lights should be on the back of the brake pedal under the dash. and the turn signal flasher should be under the dash as well. may take some searching to find exactly where the flasher is, but you should be able to find it easily.
the flasher relay (which I think is what you are talking about) is under the steering column. look for a little neon green box.
Matt
