Just as mentioned above. I get this weird vibration feeling. Whenever, i lift off the clutch alittle. You know, the type of vibration you get just before you come to a stop. And press in the clutch to not let the car stall. That feeling. I dont know what it could be. May have a loose part rumbling up against the frame or something, but please help me out. thanks!
Heh, I FEEL and SEE that vibration as well. It seems to happen if you hit the clutch while it is under load.
We all drive in a yellow Cavalier...
Does that car shudder and lurch repeatedly when you start from a stop? In that case its probably the clutch going. Mine did that until it eventually started engaging on the highway, not allowing me to go over 55mph without it fully engaging (and then losing speed). A month prior I had a CV joint and wheel cylinder go on the right side go that could've been putting too much stress on it.
1985 Chevrolet Cavalier Sedan
2.0L I4 TBI OHV
maybe the clutch cables?
Vote for my car for car of the month on www.v6z24.com..
I often have the same trouble with mine. I have a spec clutch and flywheel but i don't remember it happening when i had my stock clutch maybe something with materials? My car runs totally fine still and only does it oftenly. I mainly notice it when its cold.
My stock one did it, my SPEC one does it, just don't hit the clutch too fast when it is loaded and it won't do the earth shaking shudder.
I notice it with my stock clutch when its very cold and its been sitting for a while.
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
