when i go to start my cavy only the cluster lights come on and stay on but when i go to crank it, the car doesnt even click or grind or anything but i know the starter works, any suggestions? im thinking the computer but i have no clue any help would be appricated
When life is out of control just floor it....
get a remote starter, connect straight from battery to engine, see what happens then?
I HAVE ALREADY TRIED THAT, TRIED CROSSING OVER THE STARTER ALSO, AND FINALLY A PUSH PUTTON STARTER THAT WORKED BEFORE BUT DOESNT NOW... SO I ANY OTHER SUGGESTIONS?
if a remote starter can't turn the engine, either the starter or your power source are dead, or the engine physically can't move.
OKAY the starter works i took it off and put power to it and it turns and grinds, well when im inside and try to turn the ingnition to crank it the cluster lights up all the standard lights but they never go off like they used to after an amount of time they stay on and when i go to crank it nothing at all just the fuel pump kicking in, a garage tried to swap clusters and steal my cluster the other day before i brought it home i didnt start it since then and put the original cluster back in it.... could they have shorted out my computer?
sounds like either the battery is dead. Enough charge to light lights, but not enough to turn the starter
or its the ignition switch
