2003 eco 5 speed, stalling at light. - Maintenance and Repair Forum
Saturday, September 01, 2007 2:56 PM
Hey guys,
I did a search and I came up with some information on this. It seems alot of people have had this problem before. Im wondering if anyone found a fix.
My car is a 2003 ecotec 5-speed. No mods, and there is no code thrown when this happens.
Basically, when im comming up to a stop light and I push in the clutch the cars idle drops past 800-1000 rpms where its supposed to be and falls straight to zero and stalls out. Its like the car doesnt catch the idle as it falls.
2 things im going to check are:
1) IAC sensor, clean TB and IAC "hole".
if that doesnt work:
2) take it to the dealer and ask them to re-flash the ecu with TSB# 04-06-04-063. (according to some posts this is an ecu re-call)
Im wondering if anyone else has a recommendation OR had this problem and knows how to fix it.
Thanks.
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Re: 2003 eco 5 speed, stalling at light.
Sunday, September 02, 2007 2:28 AM
It sounds like your on the right track so far, but I doubt it's the ECM.
btw the IAC isn't a sensor.
Sunday, September 02, 2007 11:19 AM
What is it a stepper motor or something?
I dont know....." the thing that opens and closes the little hole"
Sunday, September 02, 2007 11:26 AM
when I had my 03 I got a recall notice for that exact problem.
Sunday, September 02, 2007 3:06 PM
Yeah, im not going to rule anything out. I think ill call the dealership monday and get the reflah based on the recall # above.
Monday, September 03, 2007 6:36 AM
I've had mine reflashed twice. It still does it all the time. I've been on the dealership to fix it since I got the car over 3 years ago. They basically told me they couldn't fix it cause there is nothing wrong. It seems to get worse with time, cause now mine will start to stall out at random times when idling, like siting at a stoplight.
I've asked around to lots of other technitians (not at a GM dealership), and they all seem to say it sounds like a crank sensor.
Sunday, September 16, 2007 5:24 AM
I have an 04 eco (Sunfire)
I'm out of the warranty period.
How much should a dealer charge to flash the ecu?
How much to fix the IAC?
Thanks
Walt
Sunday, September 16, 2007 6:41 AM
I have the same problem. I've cleaned the IAC, throttle body, and it's still acting up. Let me know if you get yours fixed, and what it is.
Monday, September 17, 2007 9:19 AM
hey when did these idle problems start up on your eco's? i own a 2003 cavie so im just curios if i need to be worried
Silly ricer, useless wings are for penguins.
Monday, September 17, 2007 9:30 AM
did this affect the '02 Eco's?
Desert Tuners
Tuesday, September 18, 2007 6:38 AM
alright, did a little searching this morning.
the '03's have a problem with the fuel pump. the connectors inside the tank get hot and melt. the fix is to replace the whole pump.
I also found that it might be caused by a bad crank position sensor.
Desert Tuners
Tuesday, September 18, 2007 6:59 AM
Do you have a link to that resource? I'd like to read on it.
Tuesday, September 18, 2007 7:18 AM
http://www.topix.com/forum/autos/chevrolet-cavalier/TFBEMDQVMJJ5L9SDV
hope that helps.
Desert Tuners
