DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit??? - Maintenance and Repair Forum
Friday, August 10, 2007 7:23 PM
my car will not start and its driving me crazy .. iv changed every parts known.still no luck
my car will crank like crazy but will not start.
when i use my scanner i get " mil is off" what does this mean ?
Re: DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit???
Monday, August 13, 2007 9:21 PM
MIL is off....Malfunction indicator light is off...or your check engine light.....turn the key on, does your check engine light come on when you put it in the ON position with all all the other lights....if not i would be looking into a blown PCM fuse or any other blown fuses.....
Monday, August 13, 2007 9:42 PM
all my fuses are fine... my engine light does come on though
Monday, August 13, 2007 9:43 PM
unless theres more fuses .. i see everythng is fine.. under the dash and under the hood
Tuesday, August 14, 2007 8:39 AM
which is it the 2.2 or the 2.4? if its the 2.2 it would be easy to check for spark for starters.Does the fuel pump turn on? If your not getting anything from the scanner it could be the PCM is bad.google the DTC and see what you find. sometimes i find blogs of people who have the same DTC and possible solutions.
Wednesday, August 15, 2007 5:32 AM
its a my 2.2
