Hi,
I was wondering if someone have a trick to install the engine with the trans attached. I tried and ended stock on the brake booster and when i enter the transmission first the underdrive pully stock on the frame.
thanks
Phil
Unbolt the booster from the firewall and move it aside.
Taking the booster off is an quick way of doing it, but if you angle the motor enough it does slide in.
Yea i got the engine and trans out the top all i had to do was remove the top engine mount and tranny mount everything came right out i have not put it back in though.
My car--->
http://www.cardomain.com/ride/2569452
