I was changing out my old tires and rims today for a new set and while removing the lug nuts one completely snapped off with half the bolt that it screws to with it! I am glad it happened now and not on the road because it was a very easy break. How do I replace these? I am sure it involves removing the caliper and rotor but then what after that? Any and all help quickly would be awesome as being this is the only car I have and I need it to get home. Thanks
Andrew
if your refering to the wheel stud then search in the suspension forum for wheel studs. theres a write up on how to remove and install them. i think there like 2 bucks for a stud. its pretty cheap.
yea i just found it through the search, i did not know it was called a wheel stud so it was hard to locate. Thank you
