ABS Sensor - Maintenance and Repair Forum
ABS Sensor
Tuesday, July 31, 2007 9:23 AM
Alright so im changing my wheel bearings. Tthey arent high end or anything. I think they arent brand name.
I was getting 1 side for 40 bucks.
My cousin just told me you have to get the ones with the abs sensor cus theres a connecter that connects to the hub. When I called the parts person up he said he punched in 1999 cav z24 and this is what showed up. The parts person also told me there is no sensor on the hub it is probably located somewhere else
What do I do, is it possible to still use the wheel bearings without the sensor.
Do they have a sensor in them at all?
Thanksssss
Re: ABS Sensor
Tuesday, July 31, 2007 9:46 AM
The ABS sensor is not attached to the wheel bearing, it is fixed to the spindle, the bearing has a reluctor wheel on the back that makes pulses everytime it comes near contact with the fixed sensor. So yes you do need a special wheel bearing that has the reluctor wheel. If not your abs light will come on and give you an "Excessive wheel speed variation" or something.
Re: ABS Sensor
Tuesday, July 31, 2007 9:47 AM
follow the only electrical connection on your A-arms and you will find the sensor, which is not part of the bearings.
Re: ABS Sensor
Tuesday, July 31, 2007 9:48 AM
The rear bearing has a reluctor wheel, but the reluctor wheel on the front is mounted on the axle behind the spindle.
Re: ABS Sensor
Tuesday, July 31, 2007 9:50 AM
Greg Z. wrote:The rear bearing has a reluctor wheel, but the reluctor wheel on the front is mounted on the axle behind the spindle.
+1
Re: ABS Sensor
Tuesday, July 31, 2007 10:47 AM
Yea im changing the front ones. So I need a special wheel bearing.
Do you guys know which one to use??
Re: ABS Sensor
Tuesday, July 31, 2007 10:57 AM
Ok I was curious about that.. my mistake, I dont own a J with ABS, thank god.
Re: ABS Sensor
Tuesday, July 31, 2007 10:59 AM
Gagan Kainth wrote:Yea im changing the front ones. So I need a special wheel bearing.
Nevermind, you dont need any kind of special wheel bearing in the front, only for the rear.
As long as they are the right ones then you shouldnt have any ABS related problems when changing the wheel bearing.. Just be careful not to strech the ABS wires
