Factory Warranty Cover Struts? - Maintenance and Repair Forum
Monday, July 09, 2007 8:16 PM
Hey guys I'm pretty sure my strut mount bearings are gone in my 2002 ecotec Z24, clunking when i turn steering wheel doesn't return to center properly,fades off in last direction turned. now if memory serves its under 100,000km 5 year warranty which should be comming up on expiration very shortly anyways does anyone know if this is covered in the factory warranty? im sure as hell not paying any mechanic 600 dollars to remove the struts.
Thanks
Re: Factory Warranty Cover Struts?
Tuesday, July 10, 2007 12:38 AM
yes if its not. it shouldnt be much over 100 to diy
Tuesday, July 10, 2007 1:19 AM
600 bucks for a shop to change your struts? Do the mechanics wear ties to work? thats WAY too expensive for a strut change, even including the parts.
Tuesday, July 10, 2007 5:40 AM
Everyone says mechanics are so expensive, but infact we really arent.
Front struts/mount lets say $200.
now labor, which isnt the easiest thing to. Remove struts, put in compressor, install new strut, reinstall $320, or about 3.5 hours
Than the alignment $80
$600 isnt bad
Tuesday, July 10, 2007 6:38 AM
I don't believe this crap I callled a chevy dealer in my area and she said my warranty expires today.....yeah holy crap eh so anyways i ask her about the struts and she tells me its not covered on the factory warranty, it's retarded that a known defect isn't covered on a factory warranty
Tuesday, July 10, 2007 6:44 AM
looks like I'll need to do this myself anyone with information on the subject would be greatly appreciated I've done a fair ammount of research on the org and i believe i can do it, i've got a good knowledge on basic tools, so does anyone know where i can get a whole new assembly shipped to canada for a descent price? dealer asks 100$ for mouinting plate spring seat bearing assembly anyone know if I can do b etter else where? and is there a detailed howto on th is somewhere?
Tuesday, July 10, 2007 7:22 AM
Andrew. Go to your local NAPA or part source or crappy tire and pickup new mounts yourself. I think the rears are like 35-45/each and the fronts are a little more expensive then that.
Tuesday, July 10, 2007 9:48 AM
The factory probably calls the struts themselves a "wear" item. The mounts should have been covered though.
Tuesday, July 10, 2007 6:09 PM
If your doing it yourself, you dont have a choice you need a shops helps.
You need to have a spring compressor, to compress the spring to, remove the sturt to isntall the new one.
Secondly, you live in Canada and lots of salt and such. Your more than likely goin to need use of air tools, aminly impact gun and impact sockets.
I have never been able to break loose strut bolts, by hand, and I consider myself pretty strong
Tuesday, July 10, 2007 11:12 PM
Yep, that shaft nut is gonna be tough to get off with just hand tools even if it WASN'T a car that lived on salted roads.
Wednesday, July 11, 2007 5:09 AM
Andrew, most warranties don't cover struts, they consider them wear & tear items, just like shocks from back in the day, unfortunately not as easy or as cheap as shock use to be.
Wednesday, July 11, 2007 9:28 AM
If it is a bumper to bumper warranty ... then yes, they have to replace it for free wheather they want to or not.
dan
