okay, i just finish putting on my final piece (a new egr valve) of the rebuild of my 97 2.4 motor, i went to start it and it ran for about 2-3 sec. and died
i checked the battery and it was low so i use a battery out of my van and the same thing, i listened for the fuel pump and everything came on and i saw no leaks coming from the injectors, the IAC after turning the key on than off made a buzzing noise i don't know if that's normal? once it starts and die it would have to sit for a couple of minutes to it'll start and die again, in between it'll just stall, is there a way to check for spark from the plugs? when you put the key in the theft light doesn't blank so i think the passlock is okay, i'm going crazy trying to figure this out i check everything over at least three times, HELP ME PLEASE
Fuel pump?
2000 Cavalier Coupe, 138k miles, 2.2 Auto, Silver (alive)
1999 Cavalier Sedan, 237k miles, 2.2 Auto, White (dead)
check fuel pressure. if not a fuel related issue, could be the IAC is bad.
