methos of checking for exhaust leaks - Maintenance and Repair Forum
Saturday, June 16, 2007 4:38 PM
CEL on and a code came up and i dont recall the code and i didnt think to much of it because it said bank1 lean mixture and i had a problem with my header sealing to the down pipe because it had came loose and it was just an exhaust leak. i tightened it up and cleared the code and no problem, but now i was thinking maybe it was a leak again but on visual inspection nothing stuck out and i didnt have a audible leak, also though my question is that what are different ways to check for leaks, when i worked at Baron BMW we had a smoke machine and we just turned on the car and you went around with the smoke machine until you saw the smoke being pushed away. I currently dont have a smoke machine and dont wanna buy one, so i was seeing how other people checked for small exhaust leaks? oh, and i checked the current to and from O2 sensor and it was within specs.
Re: methos of checking for exhaust leaks
Sunday, June 17, 2007 8:45 PM
Run some seafoam through the engine, it'll make a lot of smoke and just look under the car for where it's leaking out of the exhaust pipe.
2000 Cavalier Coupe, 138k miles, 2.2 Auto, Silver (alive)
1999 Cavalier Sedan, 237k miles, 2.2 Auto, White (dead)
Monday, June 18, 2007 3:35 PM
I was thinking the same thing.But also look at it this way you kill two birds with one stone
My car--->http://www.cardomain.com/ride/2569452
Monday, June 18, 2007 9:15 PM
alright will try and will post up if i find it or not, thanks for the comments
Wednesday, June 20, 2007 11:26 AM
Stick a wet rag in the exhaust to create backpressure and listen for leaks.
2002 Cavalier 2200 5spd
