TPS pinout needed please - Maintenance and Repair Forum
Friday, June 15, 2007 10:59 AM
I need the pinout for the TPS used on the 3rd gen 2200 SFI, or any other car that uses that exact sensor. Thanks.
Re: TPS pinout needed please
Friday, June 15, 2007 4:24 PM
From my 1997 manual for the 2.2
3 wires to TPS.
1- wire 416 Grey to TPS pin A is 5 volt Ref from PCM pin 33 on C2
2- wire 452 Black to TPS pin B is the sensor ground to PCM pin 57 on C1
3- wire 417 Dark Blue to TPS pin C is the throttle position sensor signal to the PCM pin 21 on C1
Mike
