It's a 2001 Pontiac Sunfire with the 2.2L engine. Washer Fluid goes in, and onto the floor. I can't figure it out. It is bone dry and I can't see any holes or anything or figure out how to get a better look. How can I take it apart to replace or investigate? Thanks guys.
Also, can anybody tell me where the drain is for the oil? I can't see a freakin' thing down there.
Oil drain is on the bottom right rear of the oil pan. As for the washer fluid, the hose for it could have come loose, or there is a hole in the bottom of the reservoir, take driver side tire off and remove the fender liner to inspect. While you have the tire and fender liner out, consider removing the intake resonator that will be in your way and giving it to your friendly neighborhood dumpster for safekeeping.
