well if you can get the bolts on the straps off easy which you probaly wont and with the tank and the lines out take about 2 minutes pretty easy
kool but I'm gonna try the relay first then if it's not it I will have to change it
ya its not too bad.. hopefully u dont have a full tank of gas
yea check all that and to make sure take off the connector on the pump and get a multimeter or test light put it on the grey wire and ground somewhere on the body and get someone to turn the ignition on you should get voltage for 2 seconds if you do the pump is dead if you dont then you got a relay or fuse blown
