is it hard to swap a 5 speed into my 4 door cavi that i bought with an auto in it? just wondering.
yes tons of work..
if it was a 2 door it would be easy as cake
need the PCM, shift cables, tranny (duh), flywheel, clutch for sure. Might as well grab the axleshafts from the donor vehicle while you are at it, as well as the engine harness. What year is your car? if its 2k up, gonna need the Getrag trans (with the proper bellhousing for your engine), if pre-2000, gonna need the suzuki trans. A cross-year swap (2k into pre-2k, or vice versa) would be WAY too expensive.
i have an 03 LS sport that i bought just cause i needed a car at the time and it has an automatic in it and i just wanted to know if it would be hard to do.
