LN2 (2200) stuttering after shifts (5sp) - Maintenance and Repair Forum
Tuesday, April 17, 2007 10:05 AM
2002 LN2 (2200) 5sp about 75k miles, new plugs, wires, coils
Ever since I replaced my plugs, wires, and coils it has stuttered or stumbled after a shift every once in a while. Not always the same gear, sometimes 3rd, sometimes 5th. only really happens at the bottom of the gear right after a shift. Part throttle or WOT. Idles fine. No skips, so I think it's sparking fine. Might be a fuel problem (lean or rich).
I think injectors or O2 sensor, but wanted to find out what you guys think before I spend $120 on a Oxygen sensor.
Yes, I read the other post of similar topic. Didn't help or sound the same.
Re: LN2 (2200) stuttering after shifts (5sp)
Tuesday, April 17, 2007 1:23 PM
Added some Gumout Maximum Clean today. Cheaper approach for right now to see what it does in a couple hundred miles.
Tuesday, April 17, 2007 4:01 PM
$120 for an O2 sensor? Unless that's a wideband you're getting ripped.
fortune cookie say:
Tuesday, April 17, 2007 4:15 PM
Mine does that a little bit in second at half throttle until around 3,000 rpm, sort of like I'm lugging the engine. If I run first gear out a little more this doesn't happen so I may very well be lugging it a little by short shifting first.
Tuesday, April 17, 2007 4:27 PM
$112 or so plus tax.
$118.72 to be exact.
Wednesday, April 18, 2007 2:56 PM
O2 after the cat is a 4-wire sensor... cost's around $100 depending on where you go.
Are you throwing a check engine light?
Head to AutoZone, if I remember correctly they do free computer checks. Unless it's something mechanical, the ECU will tell you whats wrong.
Thursday, April 19, 2007 3:08 AM
O2 after cat just tells you whether your cat is cleaning or not. One before cat controls engine.
No check engine light.
Besides, I think it's cleaned up now. Must have been dirty injectors.
