I will like the a/c to blow more air, it is very hot in this Country, already did the resistor change and it did not improve any, so I will like to replace the stock blower with a higher rpm one.
Can someone let me know which motor will fit and from what car? I hope someone has done this mod. before. Any help be appreciated.
Hi Luis
have you cleaned the A/C evaporator core, this is the first "Radiator " mesh the incoming air hits and is usually almost completely blocked with dust and debris. This greatly restricts the airflow.
If you do this first you might find you will not need a different fan.
Check this link:-
http://www.j-body.org/forums/read.php?f=29&i=57816&t=57816
Alont
I havenīt, will do, all I have done is clean the a/c radiator adding two 12" fans at that time, cleaned the engine radiator also and got the system serviced and it cools ok but the amount of air that comes out is a shame compared to other cars, thanks for the advice your probably right the evaporator core must be clogged with dust and debris.
