Hi Everyone,
I am having this issue on my wifes
2003 Sunfire GT.
No low beams - No Fog lights - High beams work fine. All bulbs were checked and even replaced as well as all related fuses.
I did a once over on the connectors to the bulbs and checked for any corrossion and found nothing.
The little ON/OFF light on the fog light switch no longer lights up.
I'm not exactly sure what has happened here, everything worked fine last week? I had some aftermarket bulbs in there but they've worked fine for the last 4-5 months.
I was told it could be a relay?
Any ideas? I am stumped.
Is it just me or is this the 3rd case of this in the past 10 days....None of us have found a cure yet.
If you figure it out....Let me know and I'll do the same
Someone told that it could be the "splice pack" located under the washer fluid jug? I guess it rots out or something. Anyone ever have that problem?
Kinda...
Mine in my 2kGT got hosed from a worn-through washer fluid hose....shot my front harness all to hell. But if there's anopther splice pack under the jug and not under the battery, i may need to check that...
Goodbye Callisto & Skaši, Hello Ishara:
2022 Kia Stinger GT2 AWD
The only thing every single person from every single walk of life on earth can truly say
they have in common is that their country is run by a bunch of fargin iceholes.
