high rpm in drive and no speed - Maintenance and Repair Forum
Tuesday, April 03, 2007 11:00 PM
ok sometime (like in a drive-thru) i have the car in drive and let off the brake and usually a car "creeps" forward. well mine doesn't...it just sits in place and when i go from one window to the next i am probably high 2's to mid 3's on my tach and only going maybe 5 mph. i have also noticed when i go off a stoplight that my rpm's are quite high and you can hear the engine working more but once again i am only going maybe 5-10 mph. so if any of you have experience this let me know what the problem is and thanks. oh and i have a 98 Z24 2.4L
Re: high rpm in drive and no speed
Wednesday, April 04, 2007 7:43 AM
check your throttle cable,any bends or kinks?Could be a transmission issue?
Edited 1 time(s). Last edited Wednesday, April 04, 2007 7:44 AM
Wednesday, April 04, 2007 10:17 AM
sounds like the transmission is an issue, happened to me, and GM gave me a new tranny (warranty) it was almost like it was slipping in neutral when accelerating
http://www.cardomain.com/ride/2267189
Wednesday, April 04, 2007 7:45 PM
ok i think i might know what the problem is. i have a transmission fluid leak. its right under the bumper on the passenger side right in front of the front passenger tire. my car came with no owners manual so i guess where do i put transmission fluid in and how can i stop the leak?
Wednesday, April 04, 2007 9:14 PM
if you look in your engine bay on the lower right you should see a red cap that is where you fill,you don't have a trans dipstick so the only way to check the fluid level is by the fluid level screw which is under the car somewhat by the lower motor mount commonly referred to as the dogbone ,I have to go my gf is wanting sex so I'll carry on tomorrow or buy yourself a Chiltons or Haynes manual
Wednesday, April 04, 2007 9:21 PM
ok i think i know what you're talking about i think i was looking at it earlier and was kind of hard to get to? but that helps a lot and hopefully this works. any specific transmission fluid i should purchase?
Wednesday, April 04, 2007 10:19 PM
Ok I'm back,You have to fill a few quarts at a time,then,with the car jacked up,hoisted preferrably,loosen that screw until fluid drains out and stops,then you will have the correct amount of fluid in the trans,trust me I went through this and took the car to a local mechanic/friend and he hoisted the car up and showed me.I was like 4 quarts low and then I overfilled by like 2 1/2 quarts.If you don't know if the car had Synthetic or not then just use Dexcron trans. fluid and def. buy a Chiltons or Haynes manual for your car,you can get them at most autoparts stores.
Wednesday, April 04, 2007 10:57 PM
will the chilton/haynes point out which screw to loosen? haha sorry for all the questions i am quite the noob when it comes to this kind of stuff but i appreciate it
Wednesday, April 04, 2007 11:21 PM
yes it will and I am still learning as well,almost all of my mods have been from researching here on the org. or from friends helping.Newbie section is a good place to ask some questions here that way some of the guys here won't jump on ya and also try searching in the search box,you might have to word your search term differently,but most questions you might have ,have probably been discussed or answered already.Also read all of the "sticky's" and FAQ's.Good luck
Thursday, April 05, 2007 9:40 AM
ok...heres my advise, coming from working 7 years at an automatic tanny shop...forget about the fill screw...drop the whole pan.
check the condition of the oil. it should be red-ish.
check the bottom of the pan for sludge and metal shavings. if either are present, take car to a tranny shop, you may be needing a new one soon.
change the filter while your there.
if its not damaged, reuse the factory pan gasket. DO NOT use felt, cork or rubber gaskets. your factory gasket is a rubber coated metal gasket, any others will leak in due time.
refill with fliud...aprox 7 quarts.
if you have a fliud leak near the bumper..its either the cooler or cooler lines, find out which it is and get it fixed.
good luck and hope its nothing major...
Join verbalwarfare.com
Thursday, April 05, 2007 10:26 AM
well my mechanic stopped by this morning and checked out it. like you said, he said it was the cooler lines, he couldn't do anything till the 17th so he told me what to do but haha i dont quite trust myself with an issue this important to the car so its going in tuesday to get fixed. yeah i really hope its nothing major because i just bought the car bout a month ago and i could not afford it at all but thanks for the advice and knowledge
Thursday, April 05, 2007 10:42 AM
at least you know how to check the fluid level now,thanks ronin for helpin out now I know who to ask my tranny questions to
Friday, April 06, 2007 7:04 PM
no prob. as long as you didnt run it too low and damage something you should be good. just keep it full till you get it to the shop.
Friday, April 06, 2007 7:19 PM
sounds like your tranny is taking a dump.. possibly just a torque converter issue
Saturday, April 07, 2007 8:27 PM
well when i fill up with fluid it runs perfectly
