For awhile my car was nice. People would comment on how it looks nice, and drives nice. That was about a year ago now.
since then my car has had a clutch line go.
O2 sensor replaced (Apparently it was throwing a rich code).
The speedo is screwed (It's still accurate, but some times it will keep rising untill it's pointing downward at my mileage. after i restart my car it will go down about 40 Km/h)
It runs like crap. Periodically i start my car and it will just immeditly die. The majority of the time it runs like crap. It has a very noticeable loss of power.
My exaust sounds like garbage, Yes i have a fart can. And almost regret putting one on my car. Still it used to sound good. Now it just sounds annoying and like crap.
The shifting from first-second is very "Bumpy" but i would probably blame this on the running like crap.
My Coolant was low! My car has 50,000 miles on it. Is that normal?
I have taken care of my car to this point. Oil changes every 3-4 k miles. Transmission oil was changed at around 40 k miles. Yes they used ATF.
Any ideas what my problems could be?
Oh, I also have quite a large stereo.
When is the last time it had a tune-up?Take off the fart-can and try a cheaper Dynomax muffler
NeedTurbo wrote:For awhile my car was nice. People would comment on how it looks nice, and drives nice. That was about a year ago now.
Okay, the sensor possibly failed, you replaced the sensor I assume. Is the check engine light out now, or still on for the O2 sensoe?
Sounds like a bad cluster, not uncommon for these cars.
This could be casued by a ton of things. You would need a scan tool to monitor the sensors, and what exaclty the car is doing.
NOT GMs fault, yours.
Since you think its related, fix the running like crap, and then see if this goes away.
No, need a pressure done to it, to find a leak
Cars still break, even though you maintain them
Yes, see above
