fuel pressure rgulator removal - Maintenance and Repair Forum
Wednesday, March 21, 2007 6:05 PM
hey quick question how do i remove the fuel pressure regulator on a 2.4 thanks
Re: fuel pressure rgulator removal
Saturday, March 24, 2007 2:51 PM
you're going to need a few tools 1.socket wrench 2. #10mm socket 3. #13mm socket 4. #13 wrench but preferably a ratcheting wrench 5. #25 & #30 torx bit 6. channel locks or a 12" cresent wrench (you will need both)
1. relieve fuel system pressure (while the car is running take out the fuel pump relay under the hood)
2. disconnect the neg batt cable
3. remove the air cleaner assembly
4. remove the fuel pressure regulator vacuum hose
5. remove the fuel rail attaching bolts (#13 wrench)
6. detach camshaft position sensor connector. (located above fuel rail)
7 remove the fuel feed line retaining bolt and remove the line from the rail (the bottom torx screw attacted to the fuel pressure regulator "FPR")
8. lift fuel rail from cylinder head
9. loosen the fuel return line retaining bracket attaching screw. rotate the bracket so that the return line can be removed
10. remove the retun line from the "FPR"
make sure you either replace the o-ring in the bottom of the "FPR" or get one that is exactaly the same i had a little issue with that. let me know if you need anything more
Officer "An invisible car came out of nowhere, hit my car and disappeared.
