one of my foglights are blowed. which bulb does it take.
ive heard it takes a 880 socket from a friend. but i dont know how worthy his opinion is!
also how hard is it to remove/change the foglight. can i access it by just simply reachin behind, or do i remove the whole light assembly to change it?
Well if it is a 03 to 05 Sunfire it is a 880 bulb..And you will have to remove the headlight to get to the fog light bulb..It not that hard remove the cover over the rad...You will see 2 bolts holding the headlight..Remove the bolts and watch there may be a shim under one of the bolts...Once the bolts are out the whole thing will slide up and out...Then just reach down and swap out the burnt out bulb and reverse order to put back together....If you want also you can switch to the 880st SilverStar bulbs if you want they work well.Best of luck.
880
Custom Made 04 CF HID Projectors
