I got a 00 Cavalier and the odometer is acting a bit funny! It has 79,ooo on it but it will flicker back and forth from normal to only showing a few numbers!
Example: Normal reading- 79534 and will change to- _9_3__ .
If you tap the dash it changes back. Has anyone had or seen or heard this problem?
Check the connector and ground wire, somethings loose.
Thanks I'll check that out!!
wen it does it, hit the top of the dash, its a problem inside the cluster
