hello i have a 95 cav z24
could someone please tell me wich is the compression of this car ... im looking to make a turbo mod but i dont know wich is the compression of this car could someone tell me please
thanks
95 cav 2.2 OHV is 9.0:1 and 2.3 is 9.5:1
sorry is a 96 my bad
do u know what is the compression on that engine ?
96 2.4 has 9.5:1 compression = 210psi.
Compression ratio is pretty much meaningless. You can run12:1 with boost. It all depend on how much you are ready to spend to tune it right.
Gilles
2.3 Ho
If it was a 426 Hemi I'd agree with you. But on a 2.4L you should get pistons with an 8.5:1 compression that will alow you to run 93 gas with a good amount of boost.
ASE Certified Techician
DaimlerChrysler Certified Techician
Va Safety Inspector
Member Of TECHNET Professionals
Member Option D Racing
On our engines you don't need to lower compression. Lower compression should only be used when you run ALOT of boost. Witch is not even 1% of the members here. Lower compression is a way to reduce the tuning time.
If you want the max power out of your setup, you go with high compression.
Gilles
2.3 Ho
Mfk-223 wrote:96 2.4 has 9.5:1 compression = 210psi.
What about the newer 2.4's? What should be the psi rating for them?
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
Around 215psi. It's only a 0.2:1 difference. Not much. Carbon deposit and other factors can changed it. It could be a bit lower for the 9.5:1 but not much.
Gilles
2.3 Ho
I did my compression a couple months ago and it was around 235 on all 4...wth I'm confused lol
2000 Camaro V6.
