Issue with 95 Cavy - Maintenance and Repair Forum
Issue with 95 Cavy
Sunday, February 04, 2007 6:07 AM
once you start the car and it reaches running temperature the car shuts off. Then once the car cools down, you can start it back up and run to the moon. I am not sure what would cause this problem. I've been told it might be the crank sensor. Any one else have any information they could give.
Thanks in advance.
"ashes to ashes and dust to dust i might leave in a body bag but never in cuffs"
Re: Issue with 95 Cavy
Sunday, February 04, 2007 9:16 PM
These things here I will list for you need to be looked at:
1). loose or faulty electrical connections at the ignition or Coil ( Ignition switch).
2). insufficent fuel reaching the fuel injectors ( Fuel pump may need Psi test done Or fuel filter plugged).
3). Vacuum leak at the gasket between the intake manifold / plenum and throttle body.
4). Fault in the engine control system ( ECU computer or wiring harness).
5). Intake air leaks, Broken Vacuum lines.
With those tips should narrow youre trouble shooting down to a minium.
Good Luck.
