sputters a bit at idle - Maintenance and Repair Forum
Tuesday, January 30, 2007 10:30 AM
i have a 99 z24 and when its at idle it sputters a bit, could this be the fuel pressure regulator or is it even a fuel problem? any ideas? thanks
Re: sputters a bit at idle
Tuesday, January 30, 2007 5:18 PM
Kevin, it may just be old spark plugs...
Clean the spark plug wells with an air compressor, pull a couple of plugs, take a look ...
Tuesday, January 30, 2007 6:54 PM
Replacing fuel filter, cleaning injectors , replacing spark plugs or cleaning them should be made as preventive maintenance, but coil housing is the cursed part on my Z-24
Wednesday, January 31, 2007 3:01 PM
thanks guys sounds like a pretty easy fix now all i have to do is get some spare time when the wind chills not 3 below. or talk my mom into letting me use her garage. thanks again.
Wednesday, January 31, 2007 4:52 PM
How do you clean injectors; injector cleaner like lucas upper cylinder lubricate?
98 j-body sedan
Wednesday, January 31, 2007 6:16 PM
You could use Fuel Injector cleaners and pour a can on the gas tank every once in while but it is better to have a prfessional take them out an clean them with ultrasound in special machines.
